Help! I installed two games on my 9210 yesterday and everything was working find until today when i just won't start up! finally when it did the lcd is on but just blank and white. Nothing happens and every like 10 minutes it restarts itself. I can only receive calls when using the front portion but I can't sms or make calls at all! Please! What should I do?
--desperado azzi
Try removing the battery for at least one minute, then put it back and check if the communicator will start normally.
If that doesn't help, try reformatting the communicator (press Ctrl+Shift+F as soon as the color of the white on the PDA-screen changes when booting the Communicator).
If that doesn't fix the problem you need to send you communicator in for repair.
doh still not workin, i guess it's off to nokia I go
