Hi
I developed an application to the UIQ 2.1 and now want to convert it to the Series 60 .
I have several questions and would be grateful for any help on either one of these questions.
(below is relevant part of RSS and CPP files ...)
1) why can't I see my menu bar ( all I see is what seems to be a default menu bar of "Options" and "Exit"😉 ?
2)why do I get a break point when trying to execute the dialog ? (the break is before the PreLayoutDynInit )
3)what is the best replacement of a CEikChoiceList in the series 60 ? (which the option to detect the choose of a specific item , and the option to see the data from an array ...) ?
Thanks a lot in advance
**** CPP file ****CEikDialog* dialog=new(ELeave) CMyAppAboutDialog(this);
if (!dialog->ExecuteLD(R_MYAPP_ABOUT_DIALOG))
return;
void CMyAppAboutDialog::PreLayoutDynInitL()
label = (CEikLabel*)Control(EMyAppControlIdAbout);
**** RSS file ****
RESOURCE DIALOG r_myapp_about_dialog
flags=EEikDialogFlagWait | EEikDialogFlagNoDrag;
title="About";
buttons = r_myapp_about_buttons;
items=
DLG_LINE
type=EEikCtLabel;
id=EMyAppControlIdAbout;
control=LABEL{txt="Bla Bla Bla";};
RESOURCE EIK_APP_INFO
menubar = r_myapp_menubar;
status_pane=R_AVKON_STATUS_PANE_LAYOUT_USUAL;
cba=R_AVKON_SOFTKEYS_OPTIONS_EXIT;
RESOURCE MENU_BAR r_myapp_menubar
titles =
MENU_TITLE
menu_pane = r_myapp_about_menu;
txt = "About";
RESOURCE MENU_PANE r_myapp_about_menu
items=
MENU_ITEM
command = EMyAppCmdAbout;
txt = "Request Info";
RESOURCE DLG_BUTTONS r_myapp_about_buttons
buttons=
DLG_BUTTON
id = EMyAppBIdOK;
button = CMBUT {txt = "OK";};
