Apps that work/don't work on 7610
20 replies · 9,282 views · Started 23 July 2004
Let's get a list going of all the apps we've tried that work or don't work on the Nokia 7610. Here is my list:
Work:
Autolock
Full Screen Caller
Handy Shopper
Call Cheater
Stopwatch
FExplorer
Psiloc Screensaver
Don't Work:
Psiloc miniGPS
Psiloc Extended Profiles
Appman (didn't actually go through with the install cuz it told me it wasn't compatible)
Extended Profiles Pro v2.07 works on the 7610
I had to uninstall it, because the trial period was over 😞
All Work Fine...
IM+ for 6600
Phillps Camcorder Pro for 6600
Photographer (release 2 days ago) (640*480 only)
jjkeylock
resco viewer
MGS 1.96
MGS Pool
Oplayer3
OggPlay 1.51
SMSExtender
Smartner Duality
Screentaker
Active Desk
Facewave
Are you sure FaceWave hasn't caused any problems on your 7610's Messaging?
Can you send a SMS or MMS perfectly?
I'm suspecting it for screwing up my phone before. Might be wrongly accused though lol :P
PS: Photographer? Is that the same version as the old 6600 one?
Lol. Of course Total irRemote doesn't work ... the 7610 doesn't have an infrared port!
But nice of you to point that out 😉
nk_au wrote:Are you sure FaceWave hasn't caused any problems on your 7610's Messaging?
Hi
Facewave was on my MMC card when I bought the phone, so perhaps it's a 'tweeked' version, not had any problems with it.
Photographer was tweeked 2 days ago to work on the 7610
http://www.openbit.com/shop/product_info/imaging/Openbit_PHOTOGRAPHER.SIS
Best
Will
drsuave wrote:miniGPS and extended profiles both seem to work on mine
The new version of Extended profiles and miniGPS that I believe were releasesd in the last couple days do not work on the 7610. They just won't launch.
This is what I have installed. It all works.
Work:
Full Screen Caller
FExplorer
Appman (it does work)
Powerball
Vexed
MGS Karting
MGS Silverball (No sound)
MGS Minesweeper
MGS MVR Pool
Lemonade Tycoon
Bounce
SmartMovie
Repligo
Worldmate
World Clock Pro
Torch
TomTom CityMaps
SlovoED
You know the default thumbnails option in Contacts? That little picture comes up when the person is calling you?
Full Screen Caller puts up a full screen picture 😃
Just installed it but don't know where it is saving the pics that i take.
Any ideas?
thanks.
Remote S60 Pro (v2.12) works.
PCRemote & PCRemoteX (from blader) don't appear to work.
If anyone has information about a working PC remote app I'd be interested.
bemused works,
frodo (c64 emu) doesnt work - anybody got a newer version than the 0.5 from last year ?
Harakiri wrote:bemused works,
ok frodo does work, there is a newer version 0.51 but not on the sourceforge site
