list , dialog , series 60
0 replies · 1,882 views · Started 03 August 2004
Hi
I am working on the Series 60.
the AppView is derived from CCoeControl .
I have some questions , please help me ,
links and example codes are more than welcomed 😊
I want to use a dialog with a choice list ,
1) can I do that ? how ?
2) if not , what can I use in the Series 60 which is close to a choice list ?
3) can I use the list in a dialog which has more than one control (for example a Edwin and a list ...)
4) should I have a problem using lists if I'm not using the CAknView ?
Thanks a lot , TE
