Problem with Multimedia Converter on pc
5 replies · 2,645 views · Started 28 September 2002
I hope for the help from all.....
The computer sets have a model (PIIII) and Win 98 Second edition...
The problem is in the video files only.. MPEG
He cant Convert to nim file
Help Plz
Try virtuadub software to convert your mpg to avi and then try again.
Look at the hints and tips on http://www.n9210.co.uk
You can also try Multimedia Converter Pro...
Multimedia Converter Pro is an enhanced version of Multimedia Converter for Nokia 9210 Communicator. It is intended for advanced users. The user has more control on converted video frame-rate, image size and audio bit-rate....
You can download it from:
http://www.forum.nokia.com/main.html
p/s: you have to register first then go to "Tools and SDKs"...
As it'd dying while encoding the video it looks like a codec problem on the PC. Does the original play in Windows Media Player without problem? .
Try having a look at this;
http://www.microsoft.com/downloads/release.asp?ReleaseID=31921&area=search&ordinal=2
Tankerx - Don't look at this message - it contains a link to a website you won't like.... sorry
