Im trying to connect to agile messenger with a gprs connection but it wont connect, it only connects with a normal dial up wap connection. My gprs is setup and works fine when im browsing wap sites but it wont work with agile messenger. can som1 help me? I am on 02 pay as you go by the way.
Agile messenger gprs connection problem
I thought that you couldn't have a GPRS tarriff on O2 Pay As You Go, i.e. you can't access GPRS and have to use WAP for browsing.
Simon
well my gprs works, i got the settings sent 2 me from 02
Yes o2 DO ALLOW gprs access now on PAYG. Im on o2 Active....and can browse normal HTML and Wap sites 😃
Still got Agile messenger problems though..... for AOL i use the proper AOL messenger and Yahoo, simply log into Yahoo 😎
you cant connect using GPRS, only way to connect using o2 phones is by using normal wap
drew wrote:you cant connect using GPRS, only way to connect using o2 phones is by using normal wap
yes you can im on orange and i have 4mb bundle of gprs they now do for pay as u go and and i can gprs all i want
look here hope this helps.
http://www.allaboutsymbian.com/forum//forum/thread/29771/
