hi! i hope to get some help regarding a small problem im experiencing with my 9210. Whenever i'd send sms messages, it will send the message to the outbox automatically, and would read: message sent to outbox. then id have to send manually through the communicator side, by pressing "send now" ...ive tried rebooting, doesn't really work...i hope you can help me with this. thanks!
In Tools - Settings, select SMS. Then in the SMS-settings dialog, choose "Immediately" as option for 'Send SMS message' (don't know if these are the correct English terms since I'm translating this from a Dutch version Communicator.
Hope this helps
Best regards
Arjen
i already tried doing that sir, but the problem still persists, it was set on "immediately" all along...would appreciate more input..thank you very much
Hmmm, strange
The only thing I can think of now is that somehow some settings are mangled or the settings file is corrupt. You can try setting it to manual, save settings, set it back to immediate and save the settings again.
If that doesn't help, maybe only a format and reinstall would help.
Anyone else got a better idea?
any other ideas? tnx
hello salaam kia hal hai abu ji main to theek hon kia ho raha hai aj kal
