:icon14:
This thread is to swap hints & tips in using the Sendo X only.
To delete message reports:
From the Menu screen go to "Logs", press right and then select Options then Clear Log.
Feel free to add other hints & tips or links to 3rd party apps.
euphoriauk2003 wrote::icon14:
This thread is to swap hints & tips in using the Sendo X only.To delete message reports:
not exactly a tip but more of question, got my sendo and it came with a cellink bluetooth headset its ok but not great as it falls out me ear, and when i take a call the back light stays off and no matter which button i press it wont come on until i switch of the headset , which bths would anyone suggest, was thinking about a jabra250 as it looks like it would stay in
One of the best features on the phone, and this is from a purely personal view, is that you can create ringtones from songs you may have in mp3, by converting them to wav. Which basically means the possibilities are endless!!
Use mp3cutter http://www.cooolsoft.com/download/MP3Cutter.EXE as it has a free trial for clips less than a minute. Save the file as a wav, then use sound recorder to ensure the sample rate is 44Khz, 16bit and mono. Then simply send the file to your handset using BT or irda. Your phone will recieve a new message. open the message, save the file using " recorder " and voila! You have perfect audio WAV file available to select as a ringtone/sms tone.
May i recommend the start of the chorus of that song that goes.... " you can ring my bell, bell, bellllllll......... ring my bell!! " God, i'm dying to know who sings that now! 🙄
jac57 wrote:not exactly a tip but more of question, got my sendo and it came with a cellink bluetooth headset its ok but not great as it falls out me ear, and when i take a call the back light stays off and no matter which button i press it wont come on until i switch of the headset , which bths would anyone suggest, was thinking about a jabra250 as it looks like it would stay in
The following seem to work OK with the Sendo X:
Ericsson HBH-200
Ericsson HBH-600 Akono
i.Tech Clip Headset
Jabra BT200
Motorola HS800
Motorola HS810
Nokia HDW-2
Nokia HS-3W
O2 G2
Plantronics M3000
PMR Mini BTHS
Xtreme ABH-204
