Problem with MMS on the Sendo X?
7 replies · 2,035 views · Started 29 August 2004
Hi all,
I am eventually going to buy a Sendo X, but I just wanted to ask if there was some problem with MMS? I read somewhere on this forum that someone had problems with it.
And also, has the unit a built in FM radio?
I'm virtually certain there are no problems with MMS. I use it ALL THE TIME! Theres just something special about taking a picture of a cold beer and sending it to your friends at work 😊
mobilewonder wrote:I'm virtually certain there are no problems with MMS. I use it ALL THE TIME! Theres just something special about taking a picture of a cold beer and sending it to your friends at work 😊
well there is a problem with mine, mms the orange settings are excactly the same as the ones from my 7650 all worked fine on that phone have not successfully sent any with the x
these are personal settings depending on the network you're on. I suggest you contact your network for the settings. In this case, Orange.
Hi all,
Many thanks for your comments. The settings from your provider, should they be for the Nokia 3650 or am I wrong now?
Hey, christian_
Yes, you can use the Nokia 3650 for over the air configuration. I did it where I live before Sendo got my providers included in their OTA list.
--gRavY
christian_ wrote:Hi all,
gOOdgRavY wrote:Hey, christian_
--gRavY
well the settings i have on my 7650 for orange from the nokia site are exactly the same as the ones that have been downloaded from the sendo site
