Web Browser / email exchanage reader
3 replies · 3,352 views · Started 02 October 2002
Hello :
Does Any one kows a web viewer for 7650 ? I Got web viewer 1.6 but gives a error every time i try to conect. - [email protected] 3
Other issue my company mail run is on an corporate exchange server , is there any program like outlook that allow to read exchange mail ?
Thanks.
Reply to [email protected]
I use WebViewer 1.6 (registered !) without any problem ....
which message do you received ??
Domi.
Set your gateway to 0.0.0.0
I dont know if you are using GPRS or GSM to get connected but if you use GPRS this will affect your WAP browsing so that you only can use WAP via GSM. In order to go back to be able to use GPRS with WAP you need to set your gateway to what is was before. (if you try to use web viewer now you will get the error message again). Easy to do but annoying as hell.
Unless anyone else has a solution for this?
[quote="SuperionX"]if you use GPRS this will affect your WAP browsing so that you only can use WAP via GSM
Unless anyone else has a solution for this?[/quote]
well the solution is quite simple... just create two different access points, with all the same parameters, but one with the gateway and the other one without 😉 then just use the one with the IP address for wap and the one with 0's for web :P
by the way... here in Italy all operators have different access points for wap and for "full internet"... and only the first one gives access to the operator's wap portal (and it is way more expensive than gprs for "web"😉
