Anybody who can think of anything to make the phone more user friendly, or additions or changes you would like to see on the X please add in this thread,
this is not a thread for bugs
Ok I will start off,
1, I would like some sort of visual indication that there is a text or voicemail message left for me when the screensaver is on, maybe the keypad could flash every 3 or 5 seconds or something like that untill I have read the message, something to catch my eye.
2, I would like to see the 2 little silver buttons on the side of the phone to be user programmable, the one on the left of mine never gets used and is wasted.
3, Would it be possible to use the camera flash as a little torch, for me it would come in handy.
4, The PTT button on the stereo headset doesn�t do anything while the MP3 player is active. My SL45i used to pause/play on a push, and if you held it down it would skip to the next song. That would be very useful if that could be added.
5, No Airplane mode; so you can use it to either free up memory or for hospitals/planes.
6, Ability to turn off the tones when the phone is switched on or off
7, To be able to use the flash led for night time camcorder use
8, Stereo bluetooth headset option.
9, Ability to choose not to have the fully implemented NOW! screen - or at least to be able to give it a background image that takes up the entire screen
10, to be able to change the size/font of the clock
11, To be able to turn off the red end-call button for when you are taking notes
12, To be able to edit you mp3s when an mp3 is playing
13, To be able to get it to play through all of the mp3's on your phone without having to add them each individually to a playlist.
14, The ability to turn on the light a bit longer. Especially since the camera needs a few seconds to adjust it's lightning. Photo's taken with the light always are too bright or too red. Either way colours are completely wrong.
15, Why is there no headset profile in its bluetooth stack? This is a sure problem since my PC bluetooth adapter only uses the Headset profile in its "audio gateway service". As does older headsets and/or carkits. 😞 So please if possible add a headset profile too.
16, The ability to select what items of the plugins you want to see at the Now!screen. Eg. I don't like to have the birthday's visible at the today/calender view, only my appointements. So I'd like to further select which detail of the wanted plugin gets displayed.
17, Also you cannot choose which plugin should be seen on the first "MyPlane" screen, you can only adjust their position. Is it possible to disable the view of certain plugins on that screen as well? Orshould we continue making another plane with just the items we want to see and choose that plane as default plane? ....hmmm... okay that solution works as well so perhaps this is rather stupid indeed...
18,At the fun side. The ability to have animated screen savers (like SE phones do). We definitly need a theme editor so that we can show off our design talents 😊
19, At the Now! screen we can show a picture as background. Unfortunatly it is shown fully opaque. It should be possible to adjust it's transparancy (brightness) in accordance with either the (main) text above or at user preference. Or at least make it possible to utilise the inbuildimage editor to adjust colour/brightness/contrast toour taste.
20, Oh... is it possible to remove (some of) the inbuild sounds? Some are really lame.
21, a sound processor on the mp3 player, or atleast be able to set the bass and treble manually
22, a slideshow for the photoablum
