jpeg not supported
3 replies · 2,162 views · Started 04 October 2004
since upgrade in firmware, my phone now does not support jpeg pictures, so i cant send mms photos it keeps saying format not supported file corrupt i can send sound files and gifs, i have wiped phone and started again no luck, now what any ideas
i think it depends of the JPEG code.
My jpg files work on my phone, so i don't really see the problem
jac57 wrote:since upgrade in firmware, my phone now does not support jpeg pictures, so i cant send mms photos it keeps saying format not supported file corrupt i can send sound files and gifs, i have wiped phone and started again no luck, now what any ideas
Hi, can you provide a link to the file, so we can check it out?
Also, does it work OK on another S60 handset (3650 / 6600 / SX1) ?
its ok done now g. cooper from sendo emailed me told me to reinstall the new firmware then reboot while holding down 5 and all ok all files now working very happy 😃
