TV on n-gage.
47 replies · 14,013 views · Started 22 October 2004
Where can i get video streams compatible with real player?
I have unlimited gprs so thats not a problem.
Is there ANY way to get shoutcast streams on there? If theres not a direct way, would i be able to mirror it from my home comp to my phone(with minimized quality etc)
Not sure if you can do it with Ngage since it doesnt support EGDE or 3G....otherwise the bandwidth will be too slow to stream any video. Its already slow enough on the 6620's using EGDE....
Here in Brazil, we have a service from TIM, called TIM TV. It works pretty fast on the n-gage.
colgate wrote:Bernardon, could you post a link to this TIM TV?
rtsp://80.207.105.249:554/live/canalXg.rm?
where X is a nunber from 2 to 14.
For example:
rtsp://80.207.105.249:554/live/canal2g.rm?
or
rtsp://80.207.105.249:554/live/canal3g.rm?
that`s it, hope that helps. Like i said, here in Brazil it`s quite fast on GPRS. I wonder in EDGE it would be just like a regular TV, hehehehe.
Hi, I'm in Brazil too 😉
I cannot connect to this url, it gives a "Can't connect" error...
is the port number correct?
Bernardon wrote:rtsp://80.207.105.249:554/live/canalXg.rm?
For example:
or
Bernardon wrote:Here in Brazil, we have a service from TIM, called TIM TV. It works pretty fast on the n-gage.
Well Bernardon, I live in Brazil too and I've bought an N-gage recently. I have no ideas about using the TIM TV ACCESS. Do I have to download any software to my n-gage? Do I have to set any special configuration? If you are already using this service, help me please ...
ah, How much are you paying for that service ?
I thought it would work on the normal GPRS acess. But as Colgate and Dyggs said, they cant connect. You have to create a new acess point. Here are the configurations for Tim Tv Acess:
MENU -> TOOLS -> SETTINGS -> CONNECTION -> ACCESS POINTS
- New Access Point, using default settings
Connection name = Tim TV
Data bearer = GPRS
Access point name = tv.tim.br
User name = tim
Prompt password = no
Password = tim
Authentication = Normal
Gateway IP address = 0.0.0.0
Mas a�, � como dizem n�, brasileiro se encontra em qualquer lugar, hehehehe.(isso se vcs forem brasileiros mesmo n�, as vezes est�o passando um tempo no Brasil s�) Pelo que eu pude ver do ingl�s de vcs, vcs n�o ter�o problemas em traduzir as configura��es. E tb se tiverem, � s� passar o idioma pra ingl�s e configurar, depois voltar pro portugu�s.
Hope that helps.
Oh and the service is FREE till december 31 this year.
De gra�a at� inje��o na testa! hehehehe
Dyggs wrote:Well Bernardon, I live in Brazil too and I've bought an N-gage recently. I have no ideas about using the TIM TV ACCESS. Do I have to download any software to my n-gage? Do I have to set any special configuration? If you are already using this service, help me please ...
Don`t need to install anything, you use the Real One Player, just enter that URL I posted before, and enjoy...
But don`t expect to watch Globo, they don`t have that channel yet.
Oh man, I really don't know how could I thank you for that information !!
I'm watching Cartoon network right now in my N-gage !
That's pretty cool !!
Quanto a ser brasileiro Bernardon n�o tenha d�vidas! Sou Baiano, de Feira de Santana! N�o falo oxenti mas amo essa terrinha ! 😊
Valeu mesmo a dica !
E n�o � que funciona mesmo! :P valeu pela dica!!
Ali�s, algu�m j� fez a listagem dos canais? Qual � o Cartoon? 😊
E sobre ser gratu�to, � apenas o servi�o at� 31/12/04 n�o? A conex�o GPRS continua sendo tarifada, n�o?
CArtoon Network is number 9 !
D�-lhe cartoon no canal nove !!!
Colgate_ wrote:E n�o � que funciona mesmo! :P valeu pela dica!!
A conex�o do tim tv � via GPRS, por�m � o GPRS do tim tv, ent�o, vc n�o paga pela conex�o. Eu ainda quero testar pra ver se consigo navegar na internet usando o ponto de acesso do Tim TV, se eu conseguir vou conseguir navegar de gra�a, heheheheheh. Ah mais uma coisa, algum de vcs est� usando outra operadora que n�o a TIM??
Valeu.
Falar em ingl�s agora, uma coisa que pode interessar tamb�m algum gringo.
Colgate, you tested the Aiptek MMC 256MB, right? You said it didn`t work. But what is your firmware version?? Mine is V3.47. I heard from here that there is a 4.10 version, but when I called Nokia service here in Brazil, they said that mine is already up-to-date. I think that the version might be the problem of the compatibility with big MMC`s, cause in the "www.n-gage.com" they say it supports up to 512MB MMC`s, and in the "www.n-gage.com/br" it`s up to 128MB only.
What do you think about that??
Eu tentei usar com OI e CLARO mas n�o funcionou.
These are the channel numbers:
Replace the letter X after the word "canal" in the following adress by one of the numbers below:
2 = Tv Camara
3 = Tv Senado
4 = Bloomberg
5 = Clima Tempo
6 = Band
7 = unavailable
8 = CNN en Espa�ol
9 = Cartoon Network
10 = unavailable
11 = Band News
12 = unavailable
13 = TVA no ar
14 = unavailable
Do you happen to know any other channels or available adresses which can be seen using the Real Player of our any gage?
aos Brazucas:
A�, Bernardon, quanto a acessar a Web utilizando esse ponto do TIM TV, o meu browser aqui n�o deixar nem a pau. Diz que � imposs�vel utulizar este ponto. Mas vamos ver a� o que podemos fazer.
Bernardon wrote:Ah mais uma coisa, algum de vcs est� usando outra operadora que n�o a TIM??
Estou usando o TIM mesmo.
Mine is 3.47 too. I tried the 256MB Aiptek card and all I got was "Card corrupted" from times to times. Then I did buy a 512MB Ridata card from eBay, this one is working without any error!
Colgate,
Colgate, you bought it from ebay, right? But how did you paid for it? As far as I know, to transfer money to the USA we have to pay a 30 Dollars tax for the bank to send the money to any USA bank account. Is that what you did?
ae Bernardon muito interessante tudo isto mesmo, estou pensando em comprar um n-gage. Como descobriram o endere�o exato do servi�o?
olharam a configura��o nos aparelhos que a tim diz serem os unicos habilitados pra tal? como por exemplo o 3650 e o 6600 ?
e se eles mudarem o endere�o como fazemos pra achar de novo ? e olhar nestes celulares que tem o programinha do tim tv access instalado dah pra saber ?
todos eles usam o real player pra tv ?
Julio Verniz wrote:ae Bernardon muito interessante tudo isto mesmo, estou pensando em comprar um n-gage. Como descobriram o endere�o exato do servi�o?
Eu descobri o endere�o pq a minha esposa trabalha na TIM 😉 . Bom n�o interessa o que a TIM diz, o q importa � que qualquer aparelho com o SO da Symbian que tenha o Real One Player, pode acessar o tim tv. Se vc olhar a configura��o de um aparelho j� configurado d� pra fazer, � s� copiar tudo e pronto. E quanto a comprar um N-gage, v� em frente, garanto que n�o vai se arrepender. E aproveita enquanto ele t� barato.
Falow
J� comprei cara ! Valeu aih!
Por essa conex�o da TIM TV d� pra acessar outros streams de video ou s� o da tim mesmo ?
I would like to access this service too, but i didn't managed...
I'm from Parana, i use Tim ... What can be wrong ??
Ah, when i try to access tim tv via Real one P. i recieve.....: "Rede GPRS ocupada"
Tim TV RULEZZZZ!!!! hehehehehe
I heard that Tim is 1 out of 3 companys in the World, that offers a tv acess for their customers. That`s nice!
Bernardon wrote:Tim TV RULEZZZZ!!!! hehehehehe
Really..!??
Oh, Brazilians almost on Top one time...haha...!!!
Its pretty good...
Bernardon, what do you say if we make a Brazilian N-gage Site...?? A litlle, just for us help to increase the n-gagers here...!!??
my msn is [email][email protected][/email], i wait your message...
There is no Real Player in The QD. Whereas in the Old N-Gage there is. So is there a Real Player or video streaming software for the N-gage QD? Just Checking? And is there other Channel we can tap into other than Brazil? 😊 :con?
