7650 Calender/Alarm
4 replies · 1,753 views · Started 09 October 2002
I used to have a Nokia 8210 and was able to go into the calender, sent up a reminder and then at the appropriate time, the alarm would sound and the reminder was shown on the screen. I dont seem to be able to find this utility of the 7650. Does it exist or similar. I did try to search for prev links but could find nothing similar on the forum. Thanks. Ian
You can set up alarms in Outlook that, whebn sync'd with the phone will raise an alarm. Haven't found it too easy to do otherwise.
Thanks for that, sadly I dont tend to use outlook too much, I have a bad short term memory and suddenly rememeber to do stuff and set up a reminder so I dont forget, that sort of thing. Ian
just go to calender, its in the shortcut as well. key in your subject and time and scroll down to alarm, set it on and set the time u want the alarm to sound. that's it.
Simple!!!
Calendar....Options....New Entry....Meeting/memo/anniversary etc etc..
you can even set the phone to ring before the meeting starts...
