Dvd to mobile software
4 replies · 1,657 views · Started 04 November 2004
has anybody tried this software with success. Try it yesterday
After converting a dvd, and passing movie to phone it gave me a audio error.
Which piece of software, exactly (application name & version)?
(Assuming that the application's name is not "Dvd to mobile".)
Also, what audio error, exactly was given (exact error message, word by word as displayed)?
Details about what settings you used to make the phone format movie, size of the file and how you passed it to the phone could also be helpful.
(Assuming that the phone is a Sendo X, but if not, you should state that, too.)
fender79 wrote:yes the software is called DVD TO MOBILE (Nokia Edition) (http://www.makayama.com/dvd2nokia.html)
error: audio int failure
Program converts dvd to small file to be used with special dvd player installed on SENDO X.
Copied directly to 1Gb SD card.
it is better than smartmovie?
nic85 wrote:it is better than smartmovie?
but u can only convert dvd files?not divx,avi ecc.?
