Is it possible to send .sis file on Nokia 660 via bluetooth, but without renaming it into
.s file?
Will this change if I update a new firmware?
Thanks 😉
Sending .sis file
Not with built-in software, and firmware updates will not help either.
so the best method is by using ZipMAN :redface: plus the extension pak 😃 😃
SeleQ allows you to send any file via bluetooth, ir, mms and email
Gazzeh wrote:SeleQ allows you to send any file via bluetooth, ir, mms and email
not true :frown: It's the same.
But there must be something to do to allow sending .sis and .mid files. Don't know what :tongue:
just rename the .sis file! remove the '.sis ' from it and voila! it works! note that sometimes it doesnt :P
same thing for .mid, just remove that extension! but this also works only in nokia!
rename file with an underscore at the end, i.e. xxx.sis_
No need to rename on receiving end, file will install because OS only reads first 3 letters of dot extension to invoke installer.
thank u
EinZtein wrote:rename file with an underscore at the end, i.e. xxx.sis_
Nice. :icon14: Good point
Hi bros,
How abt sending sis files thru mms?? I was prompted that it is a protect file although I've change the file name.and still couldn't send. I tried with fexplorer v1.11.
Thanx in advance.
