Reject unwanted calls with BlackList
12 replies · 7,967 views · Started 12 November 2004
Hi all!
I'm from Italy, so excuse me if my english is not perfect!
Some questions:
BlackList is compatible with Nokia 6630 UMTS ?
I've readed that on Nokia 6600 and 7610 there could be small delay (about 0.5 second) before unwanted call will be rejected. Unfortunately Nokia 6600 and 7610 don't have API for a fast call refusal.
Has the 6630 API for a fast call refusal ??
Ciaoo
Hi :ciao:
Nobody know yet, :dontknow:
Dont know anything about 3th party applicitaion on 6630...
I hope that I will have one untill end of the week under my finger tips 😃
I will try and reporte :listen: about must have application, which work, whic not...
cheers 🙄
😛cguru:
Apocalypso wrote:Hi :ciao:
cheers 🙄
😛cguru:
Ciao!
Advanced Call Manager doesn't work
BlackList doesn't work
I hope softwarehouses soon will release upgrades compatible with Nokia 6630
bye
macuser wrote:Ciao!
bye
Hi :wavey:
What about other stuff like.... :deal:
- automatically get your emails on a preselected time
- SMS storage can again be on the RS-MMC
- use nightmode when videocapturing
- gallery has a search function
- image slideshow app
- realplayer can play in fullscreen-mode
- when downloading POP3 emails you can select to download only the header, email+attachments or give a size for the max download.
- navikey directions can be used for shortcuts (7 idle shortcuts)
- transfer all your contacts, calendar, pictures, videos, sounds, settings to or from another S60 device (I waited so long for this!)
- set automatic SMS reply if phonecall cant be answered
- screensaver shows actual profile
- the SAR (specific absorption rate / radiation) is 0,83 w/kg (which is much, Nokia 7650 has 0,35; 7610 has 0,54)
- offline profile
- add new profiles
- worldtime-clock
- flight mode
- Animated welcome logo
- Light time-out
- automatically adjusted the brighness of the display
Regards
😛cguru:
What about Nokia 6670 ?
I've just bought one and I'm having that 0.5 sec delay before it rejects the call.
Any idea if it's the same problem as with nokia 6600 and 7610 ?
macuser wrote:Hi all!
Some questions:
Ciaoo
Can't vouch for the 6630 (just bought mine and haven't tried any 3rd party software yet) but there's a program called Blackballer (http://www.killermobile.com/) which does exactly the same as BlackList but works on the 6600 with no delay at all.
Some questions:
Ciaoo
Hi Friend, U need an application for rejecting calls for 6630? yes U have "Call Control",it works well with 6630
Siddharth wrote:Blackballer also works with 6630
Really? , i've downloaded the trial but didnt get it to work!
(in the zip are 3 files could you tell me wich one you used?)
I've also tried Autopilot from the same company , couldn't get that to work either , so if someone knows hoe to get these 2 proggs to work , drop a line here......
Hmm are you guys pulling my leg? because i cant f*****g get this app to work? can someone help me? do i need to do anything else other than install and then create a list + add a person from my phonebook?
I've installed the version called "BlackBaller_1.1.2_full_6630_7610_DotSiS.sis"
also tried the version "BlackBaller_6630_7610.SIS" neither works for me.
FYI:
All my contacts phonenumbers start with + and the international prefix then the number maybe thats the problem or what do you think, so anyone using this app on Nokia 6630 please let me know how to!!
/Doggen
