Hello everyone..
I've got Sony Ericsson P900 Mobile which has low storage space for musics and a lot of software.. So, I decided to buy a Sony Memory Stick Duo 128MB , but I surprised of its price.. I don't know why its so expensive. So , I looked fot alternative MS Duo, I found one that is named SanDisk and its so cheap , 128MB for $17 .
The question is, Would MS Duo that is made by companies other than Sony work on P900 mobile ? If yes, would it make any troubles later ?
Do you recommend me to buy SanDisk MS Duo ?
Regards,
It will work just fine! They are all the same, only the name changes (and the price). I just bought a P910i and it came with a 32mb Sandisk duo!!! Even Sony is buying from them now 😉
I've been using SANDISK since my P900...
Now with my P910i i'm using a 1GB SANDISK.
SANDISK is a better choice bcoz:
1. better price.
2. you get 5 years warranty.
3. they still giveaway those ms adaptors.
:icon14: :icon14: :icon14:
Yup, I also have a SANDISK 128mb for my P900 which I got last month - no problems so far.
It too came with an extra adapter and like you said is much cheaper than a Sony branded one.
