disable lock keypad??
12 replies · 4,630 views · Started 14 October 2002
Is there a app so when i close the keypad it won't ask to lock the keypad?
But instead just let it open...
Also when i'm calling and close the keypad the call is closed 😞
Is there a way it will just stay open?
Please someone make this app... i know lots of peeps want it 😉
well, u can just close the keypad and leave it, after a few second the message asking u to lock keypad will dissapear.
for the 2nd case, what i normally do is after keying in or found the number to call from my contact, I will close the keypad 1st before pressing the joystick to dial. Then I wouldn't hav to leave the keypad open while talking.
Anyway,I guess the closing of keypad ending a call is a good features.
Ximplify SeleQ get this it will auto lock and unlock your keypad plus the new version 1.20 will let you change your logo to any colour picture you want......
get it here www.ximplify.com
About closing the keypad...
While dialing, wait for the "Options" to apear and press it. Then you can close the keypad.
This is stated in the manual also.
where is the option to auto lock and unlock in Seleq?
I cant find it 😞
[edit]
Aaaah found it, but it works the wrong way around 😞
i need it NOT to lock up and NOT to close the connection when calling
[/edit]
take e-profile from psiLOC,(the new prof.beta-version)
there u can do it like u want:
Ask-for-lock,
dont-lock,
lock immediatly.
(and in each profile u can set another key:
I have outside automatic,
@home: no lock 😉
there are some other helpful features inside,like:
-add.new alarm-ton/calendar-ton!!
-sett the powerlevel of your alarm/calendar-ton!!!
(it works!!!!
u only remove all the Alarms ones...
if u got Handy-clock from epocware:first have to delet the hidden file named:clock in the directory:C/clock(selecQ or with handybook also...
and u will have some midis from Z and the possibility to add all the wav/amr u want for Alarm/calendar)
-time-based setting of your profil.
(like @ 8310/6510 but quiet better and multi-setting-function.)
- Add a coulour of:blue/green/violet-skin from phone @ each profile.
-Add backgrounds(even gifs:they work togther with the screensaver!!!)
@each profile 😉
(so u can see really good,what profile u got in moment:
differents backgrounds for each situation....
i start to test it out 2 days now,and i�m really happy with it:
not anymore big and bugy,real stabil and the 10 boxes worth...
(but the trial works anyway with no limit:
they say 21days,but if i test it out with different dates,it mworks also in the jear 2005 😉 )
S�mi
Seleq is good but the features are not documented well. I can't still find where you activate Auto Lock.
System > Autokey Key Guard seems to do the trick but only in that menu. Once you return to main menu "Lock Keypad?" still appears
System > Autokey Key Guard seems to do the trick but only while you are in SeleQ. Once you exit the program "Lock Keypad?" still appears.
[quote="iarditi"]Seleq is good but the features are not documented well. I can't still find where you activate Auto Lock.
System > Autokey Key Guard seems to do the trick but only while you are in SeleQ. Once you exit the program "Lock Keypad?" still appears.[/quote]
you should not exit SeleQ for auto lock to work. Instead, while SeleQ is still open, just press the Menu button to switch from Menu to Stand-by, thus leaving SeleQ open. To check what programs are running, while on standby screen/mode, press and hold menu button for about 2 secs, then on the upper left of the display, it'll show you which programs are running.
Hope this helps.
eProfile.
my dream application.
Psiloc simply the best symbian developer. 😃
e-profile is not working with the Dutch version of Symbian 😞
And i don't want to change it to english...
Well i just have to wait until the dutch version comes available 😊
