Below is the e-mail from ximplify
Dear friends,
I am pleased to inform you that the latest version of Ximplify SeleQ is
available for download now from www.ximplify.com.
This is a free upgrade to all registered users of Ximplify SeleQ 1.00
and 1.10i. Just download the trial version and install to your Nokia
7650. You don't need a new License Key or buy a new copy, this is an
upgrade.
Version 1.20i of Ximplify SeleQ has the following new features:
1. Set Operator Logo - One of the most requested function in web forums
is now available for free. Use SeleQ to choose any image file in your
phone (*.bmp, *.jpg or *.gif) and set it as operator logo. SeleQ will
automatically resize and rename the image for you according to your
Operator settings.
2. Copy Inbox - Copy attachments from your messaging Inbox and paste it
to any selected folder.
3. Run Symbian EXE file via Open command.
4. Additional language versions including Danish, Dutch, French,
Portuguese and Spanish thanks to our translators around the world.
With the release of the new version, the Special Introductory price of
USD12.00 has also ended. From now on, Ximplify SeleQ will be sold at
it's Normal price of USD18.00.
Thank you for all you early buyers. We appreciate your support and
feedbacks.
just downloaded it way cooooooooolllllllll !!!!!!!!!!!!!!!!!!!!! 😃 😃 😃 😃
yeah....thanks.....
just tried it ....its great........... 😃 😃[/b]
sorry but..where is the option to set the op.logo??I just upgrade but..cant find it
[quote="Global moderator"]sorry but..where is the option to set the op.logo??I just upgrade but..cant find it[/quote]
In SeleQ, Just go to C: > Nokia > Images > Select the image you want to set as OP logo press joystick and scroll to "set as op logo" -- phone will reset and viola!
[quote="vtr"][quote="Global moderator"]sorry but..where is the option to set the op.logo??I just upgrade but..cant find it[/quote]
In SeleQ, Just go to C: > Nokia > Images > Select the image you want to set as OP logo press joystick and scroll to "set as op logo" -- phone will reset and viola![/quote]
u right 😮ops:
Thanks for the reply
Select image whit the SeleQ, then press "Options" --> "File" --> "Set as op..."
Edit: Too late... 😮ops:
and if you want your operator name back, what do you have to do then?
thanks
another question..if u go options-->settings there is audio!I set it on but what this is all abouter 6..eemmm sorry 😊 what this is about??(the audio option)
[quote="racingboy"]and if you want your operator name back, what do you have to do then?
thanks[/quote]
Simply delete or rename the pictore.
And the picture was in folder "C:\system\apps\phone\oplogo".
I dont know what the sound-settings does in there??? Is it notify-alarm-sound??
It is used to play music file. 😃
Just select the music file you want to play(*.mid;*.wav;*.rng)
Then select Options->File->Play or
Press thejoystick & select Play.
I've just updated my SeleQ to V1.2. I also try using those new features. It works fine. I think it's one of a good software for 7650, isn't?
I think its an essential tool, thats why I bought it!
