I have the following PKG File:
; lp.pkg
;Language - standard language definitions
&EN
; SIS file header
#{"LightPlus"},(0x10204B53),1,1,0
; Only two files to install for the minimal application
"LightPlus.app"-"!:\system\apps\LightPlus\LightPlus.app"
"LightPlus.aif"-"!:\system\apps\LightPlus\LightPlus.aif"
"start.mbm"-"!:\system\apps\LightPlus\start.mbm"
How can I show the Developer Name when I install the SIS ? I only can see the Name of the program and the second line is emty.
add this line:
"I:\system\APPS-DIRECTORY-IN-PC\yourname.txt"" -"",FILETEXT, TEXTCONTINUE
and ofcourse create new file.
for other languages except english i suggest unicode into txt file
Thats not what I mean, look at my Screenshot . I am looking for the Text for "Anbieter" after the Field "Name" !
jojo wrote:add this line:
"I:\system\APPS-DIRECTORY-IN-PC\yourname.txt"" -"",FILETEXT, TEXTCONTINUEand ofcourse create new file.
*"D:\JOJO\1\key.key","D:\JOJO\1\cer.cer"
u need .key and .cer files
Whats that .key and .cer ?
jojo wrote:*"D:\JOJO\1\key.key","D:\JOJO\1\cer.cer"
search your PC and find similar files😊
certificate files and the keys for them
You can use makekeys to make a self signed certificate (from the help file):
makekeys -cert -dname "CN=Symbian OU=Development OR=Symbian Ltd CO=GB" mykey.key mycert.cer
Makekeys asks you to move the mouse around to create random data. After that you need to supply as password for the key.
The following step is include it in the PKG file with the following line:
*mykey.key,mycert.cer[,KEY=privatekey-password]
If you omit the KEY= part, makesis will ask you for the password every time you create a sis file
Hope this helps.
