Reset Series 80 with OPl Command
3 replies · 1,872 views · Started 04 December 2004
Roman wrote:Is it possible to reset a Series 80 device with OPL and how ?
No, not possible from OPL. It is possible to call another application that resets the phone though. If you use SyRunExe& on the attached Symbian executable, the Communicator will reboot (at least 9210, don't know about 9500). A warning though: running Reboot.exe will instantly reboot the 9210, all changes to files open in other programs are lost.
Hope this helps.
Attachments: REBOOT.zip (515 B)
I have the following code now and I get an error like: The string is too long !
Whats this ?
Proc reboot:
local file$(9)
file$="(REBOOT.EXE"😉
SyRunExe&😞file$)
ENDAPP
Count the characters used in file$. I count 10, one more than 9 😊
Also I think you have to specify the full path to REBOOT.EXE.
