Has anyone else had probelms with FExplorer on the 6630? I have been unable to use it to take screenshots. Also usage has crashed my phone at least once, quite severely. Took a while for it to reboot and then even longer to get a signal back. All seems to be well now.
In the meantime is there any other program that allows screenshots to be taken? I tried the freeware one from Symbianware but that did not work either.
FExplorer screenshots and other features works fine for me on a 6630. Are you using version 1.11 and not some older release? Get the latest from http://www.gosymbian.com/
With Screentaker from www.symbianware.com you can create also screenshots for free!!
Only problem with Fexplorer onthe 6630 is that the icons dont appear to load problperly for me (the ones that show the file is associated with a certain program) just shows up as a grey and voilet box.
RS77 wrote:With Screentaker from www.symbianware.com you can create also screenshots for free!!
FEXPLORER is also free and works exactly as advertised on my 6630
NoBackup wrote:FEXPLORER is also free and works exactly as advertised on my 6630
:icon14: exactly the same for me
