o2 wap settings
2 replies · 3,146 views · Started 30 December 2004
hi guys iv just got this 6600 and cant get the o2 wap settings iv tryied the o2 website and the nokia site and they do send the settings but they dont access the wap or mms,could somebody set out the settings for me because im about to drop kick this phone out the window it would be much appreciated..........cheers 😡
davy wrote:hi guys iv just got this 6600 and cant get the o2 wap settings iv tryied the o2 website and the nokia site and they do send the settings but they dont access the wap or mms,could somebody set out the settings for me because im about to drop kick this phone out the window it would be much appreciated..........cheers 😡
davy,
have you tried asking o2 for the sim updates? the settings won't work unless the service is activated on your sim card.
be sure to ask them specifically for the SIM UPDATE as the call centre staff can sometimes get a little confused or try to get you off the phone by sending you the access point settings over & over.
if this doesn't work try using the search option at the top of the forum.
good luck.
are you on pay and go? Change the username from o2wap to payandgo (you need to do same for mms settings too). My brother and I had same problem and spent hours on phone to o2 getting it sorted 😡
