PLEASE HELP , try to hang up an outgoing call
4 replies · 5,090 views · Started 03 January 2005
Hi
I found code that can trace a dialing status .
I try to use it in a very simple and primitive way :
I want to hang up the call when status changes to dialing.
what actually happens is that when I dial a number and the app is in the background , I get a message that my app is closed , and the call is made (not hung up).
so the dialing status does activate the RunL() method , but the app falls.
please advise , what should I change or add ?
I put the code below , I think that the most relevant method here is the RunL() ...
Thanks in advance , TE
CActiveClass* CActiveClass::NewL()
CActiveClass* self = new (ELeave) CActiveClass();
CleanupStack::PushL(self);
self->ConstructL();
CleanupStack::Pop(self);
return self;
CActiveClass::CActiveClass()
: CActive(0){}
void CActiveClass::ConstructL()
iEnv = CEikonEnv::Static();
CActiveScheduler::Add(this);
StartObserver();
CActiveClass::~CActiveClass()
if (IsActive())
Cancel();
else
ReleasePhone();
void CActiveClass::RunL()
if (iStatus == KErrNone)
if (iCallStatus == RCall::EStatusHangingUp || iCallStatus == RCall::EStatusIdle || iCallStatus == RCall::EStatusUnknown)
iCall.Close();
else if(iCallStatus == RCall::EStatusDialling)
RCall iCall2;
// Try : iCall2.OpenExistingCall(iPhone,iName);
iCall2.OpenExistingCall(iLine,iName);
// Try : iCall2.DialCancel ();
// Try : iCall2.HangUp(iStatus);
iCall2.HangUp();
iLine.NotifyStatusChange(iStatus, iCallStatus);
SetActive();
void CActiveClass:😃oCancel()
ReleasePhone();
void CActiveClass::StartObserver()
Cancel();
if (InitializePhone() == KErrNone)
SetActive();
TInt CActiveClass::InitializePhone()
TInt theError;
if (iLineInited)
return KErrNone;
theError = iTelServer.Connect();
if (theError)
return theError;
// Find the number of phones available from the tel server
TInt numberPhones;
theError = iTelServer.EnumeratePhones(numberPhones);
if (theError)
iTelServer.Close();
return theError;
// Check there are available phones
if (numberPhones < 1)
iTelServer.Close();
return KErrNotFound;
// Read the TSY module name
theError = iTelServer.GetTsyName(0, iTsyName);
if (theError != KErrNone)
iTelServer.Close();
return theError;
// Load in the phone device driver
theError = iTelServer.LoadPhoneModule(iTsyName);
if (theError)
iTelServer.Close();
return theError;
// Get info about the first available phone
RTelServer::TPhoneInfo info;
theError = iTelServer.GetPhoneInfo(0, info);
if (theError)
iTelServer.UnloadPhoneModule(iTsyName);
iTelServer.Close();
return theError;
// Use this info to open a connection to the phone, the phone is identified by its name
theError = iPhone.Open(iTelServer, info.iName);
if (theError)
iTelServer.Close();
return theError;
// Get info about the first line from the phone
RPhone::TLineInfo lineInfo;
theError = iPhone.GetLineInfo(0, lineInfo);
if (theError)
iPhone.Close();
iTelServer.Close();
return theError;
// Use this to open a line
theError = iLine.Open(iPhone, lineInfo.iName);
if (theError)
iPhone.Close();
iTelServer.Close();
return theError;
return KErrNone;
void CActiveClass::ReleasePhone()
iLine.NotifyIncomingCallCancel();
iLine.Close();
iPhone.Close();
iTelServer.Close();
I now use the lineInfo.iNameOfLastCallAdded retrieved with iLine.GetInfo ,
still the call doesnt HangUp - actually nothing happens after I initiate a phone call.
I'm sure that I get to the if(iCallStatus == RCall::EStatusDialling) block .
I did many changes and tests but nothing stopped the call , also tried the DialCancel method ...
Thanks for your help , TE
iCall.Close();
RCall iCall;
RLine::TLineInfo lineInfo;
iLine.GetInfo(lineInfo);
TInt aResult = User::LeaveIfError(iCall.OpenExistingCall(iLine, lineInfo.iNameOfLastCallAdded));
iCall.HangUp();
SetActive();
self->ConstructL();
return self;
: CActive(0)
iLineInited = EFalse;
iCallActive = EFalse;
User::LeaveIfError(iTimer.CreateLocal());
TRequestStatus aStatus;
StartObserver();
Cancel();
SetActive();
TInt theError;
if (iLineInited)
return KErrNone;
TInt numberPhones;
iLineInited = ETrue;
return KErrNone;
could this be related to the ownership of the call ?
I checked and the ownership's status is not owned ...
does it metter ?
can this be the reason that I can't hang up the Call ?
Thanks a lot , TE
Update :
the HangUp works on the Nokia 6600 but only when I replace the EStatusDialling to EStatusConnected .
that means that the hang up occures only when the destination phone answers the outgoing call which is not good for my needs .(maybe its good for a broken heart guy who wants to call his ex girlfriend and hang up immediatly 😊)
its like the hang up is not supported at the StatusDialling ...
Any ideas ?
