any one know how to upload pictures to simplify clock it? i use the trial program now and will buy it if i can upload the picture. simplify site provides no in on this.
ximplify clock
😃 If i'm not mistaken, u will only be able to do this with the registered version... not on the trial version.
Clok It! only uses mbm file at present, if the image you want to use is a jpg or bitmap then open the image in Imaging and there is an option to save as a mbm. Make sure you name the file with the mbm extension e.g. image.mbm. This should also work in the evaluation version.
thanks a lot. but i tried mbm file with the trial version and still failed. does it work only with registered version? please confirm and thanks.
