(real problem solution here - could this thread be sticky?)
Hello 😊
Being stunned by Nokia's ability to destroy my boyfriend's SMS that i sent him, i looked for a solution. A friend of mine in italy (i'm myself in Thailand so this is int'l teamwork) today named me an application yet he wasn't sure if it would work.
I googled for hours and finally was able to find and download the really small (TWO kilobytes!!) thingy, and install it on my boyfriend's 6260.
IT WORKS!!!!
Here is what you need to do:
Download the attachment to this thread. (To the moderators: the attached ZIP file contains "MSdriveE.sis" which is NOT a crack/copy/warez but a freeware which only is DAMN hard to find!)
Unzip the file, you will find "MSdriveE.sis". Put this on your 6260 by means of bluetooth, IrDA or directly to MMC via MMC reader device. DO NOT INSTALL JUST YET!
Make sure the file is on MMC! Do not keep it in messages inbox, move it from there using a file manager like fExplorer (freeware, google it).
Take a note of your message centre number (messaging - options - settings - text message - message centre in use) because it will be needed.
THEN install the small application from drive e, using the file manager software. Install it to MMC only!
Afterwards, in menu you will find a new application, "MSdriveE". Run it ONCE (!!!), it will seemingly do nothing and just exit after about 30 seconds. BUT........
NOW YOUR MESSAGES ARE SET TO MMC USE!!!!!! As the MMC card icon on top, when inside the "Messaging" menu, will confirm.
Now, before you can send SMS, you will need to re-input your message centre number, because it has been deleted. You will also need to tell MMS settings again which access point to use. AND all your stored messages will have seemingly disappeared - it happens only this one time and NEVER again, believe me. They are still there by the way, but in the phone memory, and can no longer be accessed.
Now, opposed to 3650 an d the like, you can NOT switch between phone and MMC memory - it is MMC only from now on. To get back to phone, you need to take the MMC out and reboot the phone without MMC. Upon entering the "Messaging" menu, it will switch to phone memory. To get back to MMC, simply run MSdriveE application again.
Kindest regards.....
your Thanh
