don't know
i just converted a file but no idea where it was gone
where to find converted files ? lol
um...
another problem
it says
MMcomverter.exe has generated errors and will be closed by windows
you will need to restart the program.
an error log is being created
so...what to do ?
I think most probably your converted file is not saved... (due to the errors). After conversion, save the file at desired location... 😉
Uninstall it completely (this may involve a trip to the registry). Download and install the latest version available from www.nokia.com
I reinstall it many times ...still
I also used the pro ver but its the same error
