how can u Copy attachments from your messaging Inbox to any selected folder?
i have SeleQ but don't know how to do it, can anyone help. :roll:
First you need the latest SeleQ 1.2i
then go to Option - Edit - Copy inbox 😃 😃
I have SeleQ 1.2i, i'm doing what u told me. i open SeleQ go to Option - Edit - Copy inbox but i get a (SeleQ System error) does anyone know what to do?
Yep, I get the same error 😞
Come on guys! 😞
Someone should know how to copy your inbox to another folder using SeleQ??? :roll:
I get the same error... thought it was just me!
Another way of doing it is to search for the file. If it ends in JAD for example search for *.Jar or if it's called angela search for Angela.* then just copy and paste it where you want.
I get the same error! :x
A-ha, I got the same error but now solved. 😃
I found that it is working only when I have setup a mailbox & after retrieving mail. :-?
I' ve feedback to Ximplify.
They said the function is used to copied inbox & mailbox attachment but they latter realized that it should be working even when there is no mailbox setup. They said that it will be fixed to support in the next version soon. (with other new features added to SeleQ as they promissed to me 😃 😃 .)
Nice to hear that! If Ximplify read this! Make SeleQ more Filemanager like! meaning add filemanager like featuresn not crappy ones that have nothing to do with filemanagers 😃
