mp3 player
12 replies · 8,784 views · Started 01 February 2005
mertt wrote:is there a mp3 player application, better than sx1's pre-installed mp3 player?
MP3Go by m-internet.com
MP3Go for Nokia Series 60 is a MP3 music player running on Nokia Series 60 phone such as Nokia 7650/3650, so you can play MP3 songs stored in the main memory or MMC memory card (recommended) Features: Support MPEG-1 layer 3 file in 24K/32K/64k/128...
Mp3Player by Viking Informatics
Mp3Player is an MPEG Layer 3 audio player for Nokia 7650 and 3650. Supports MPEG-1, MPEG-2 and MPEG-2.5 files, from 8kHz to 44.1kHz, from 8kbps to 420kpbs. Features: plays MP3 files (MPEG-1, MPEG-2, MPEG-2.5); displays bitrate, frequency and mono...
UltraMP3 by Lonely Cat Games
UltraMP3 is a music player for your mobile phone. It is a handy application with cool graphical user interface, allowing you to listen to your favorite music on your Symbian mobile device. UltraMP3 loads and plays music in MP3 format, as well as MOD, XM, ...
MP3 Gravity by Free Gravity Oy
MP3Gravity is an MP3 music player for NOKIA 3600, 3650, 3660 and N-Gage. You can play MP3 songs stored in the main memory or MMC memory card (recommended) in the phone. Load more skins from web or create your own. Features: Support of MP3 music in...
Get more guides and advice at:
www.symbian-freak.com
Apocalypso wrote:MP3Go by m-internet.com
...but I would personally suggest the Ogg player ^^ You'll just have to convert your Cd's to Ogg format...
fgpx78 wrote:...but I would personally suggest the Ogg player ^^ You'll just have to convert your Cd's to Ogg format...
No way,
almost everybody have a large collections ofd mp3 music, whay tu bulid new ogg base!?
Dont waste your time to converting all music into ogg format, install lame encoder and force MP3.
No hard feelings 😊
cheers
mertt wrote:but noone of these mp3 players have better quality than sx1's pre-installed mp3 player
Ogg is probably better on sound, and looks better as well (especially with the iPogg2 skin!). The fact that the Ogg files are smaller for similar/better sound surely counts for something - I'm typically using 96kbps files; mp3 at that bitrate would sound pretty ropy, with no decent stereo separation, cluttering of the soundstage, etc, but Ogg does a pretty good job.
And if you've got a fairly fast PC, it doesn't take much time at all to convert from mp3/cd/wmv to Ogg either (couple of minutes for a full CDs worth of audio).
Why?
One word... size
No, all those will only play in 16KHz MONO when the SX-1 is capable of 44.1KHz STEREO output. Makes no sense to use any of those and restrict the phone to poor quality mono output.
OggPlay is a brilliant solution, 44.1KHz stereo output on the SX-1 and .ogg files are much smaller than mp3's of similar sound quality. And converting audio to .ogg is very easy and quick with dBpowerAmp 😉
As far as I am aware, OggPlay is the only 3rd party audio player that outputs in 44.1KHz stereo on handsets that support it. Using anything else is a waste of time.
I have to correct you here because Real Player as well as Helix Player can output in 44.1khz Stereo. Helix can also play MP3 and wideband AMR while both real and Helix can play *.ra (RealAudio) files.
Either way though I still recommend oggplay. It is far superior than any other because:
1.Oggplay as well as the Ogg Vorbis format are open source...
2.Ogg files with 64kbps have the same quality with mp3 at 128kbps. Double your music with no need to buy another MMC.
3.The User interface is maybe the biggest advantage of Oggplay against every other MP3 player.
4. It uses much less CPU than the other MP3 players (only the built in MP3 player can beat oggplay in this section for 1-2% less CPU usage) and so less battery consuming.
5. And as you all mentioned above Stereo AND 44.1 Khz Quality
verk wrote:almost everybody have a large collections ofd mp3 music, whay tu bulid new ogg base!?
Why?
One word... size
I never understand peoples problems, especially with Mobiles, about converting from MP3 or CD to another format like Ogg. I've got a P4 1.7gHz laptop, and it'll convert an hours worth of music to Ogg in about 5 minutes or less, so its not time consuming. Couple that with my MMC card reader, and I can have that hours worth of music onto the phone in about 5 or 6 minutes (ie. dbPowerAmp copies to the MMC card). Its almost a total non-issue.
And the Ogg interface, especially with the iPogg skin, is absolutely fantastic (apart from the useless graphic eq display).
clonmult wrote:I never understand peoples problems, especially ...
I think there is a disadvantage is, for non-MMF version of OGGplay, it does not support bluetooth headset.
