Image-Uploader works with my own Server! Try it for yourself
25 replies · 7,621 views · Started 23 October 2002
Please try my own Image Server and transfer your images via the ImageUploader within the Photo-Application.
You can visit the Server under this adress: http://www.prinzip.com/nokia/
The configs:
Image Server Name: Prinzip
Access Point in Use: (Use GPRS or HSCSD)
User name: abcd
Password: abcd
URL address: https://www.prinzip.com
Auto folder naming: Off
- Upload: Select Image uploader / Upload
- Accept untrusted certificate + continue
- Please note: Creation of own folders and upload of a folders is not supported yet.
BUT: I have a big problem:
Due to the untrusted certificate (i create my own certificate rathter than buying one from e.g. cybertrust) i changed a 7650-configuration some time ago and i can�t find it now... ...it was named something like "Accept trusted certificates in WAP only" and it has to be changed from YES to NO to make the uploader work with my certificate.
Please help me, the first one who finds this option will get a password-protected image folder of his own!
feel free to contact me via mail: [email protected]
I'd be interested in how you achieved this. If someone were to offer some server space we could set this up and have it as a place for people to upload images to and then show them off in this forum.
An extnention of this idea is to have a place for people to upload stuff to to link to from the forums. Anyone got some spare bandwith space to donate?
Rafe
[quote="Rafe"]I'd be interested in how you achieved this. If someone were to offer some server space we could set this up and have it as a place for people to upload images to and then show them off in this forum.
An extnention of this idea is to have a place for people to upload stuff to to link to from the forums. Anyone got some spare bandwith space to donate?[/quote]
Bandwidth and space is no problem, I have about 300Gigs left on my Server (Dual P4) and I have nearly unlimited traffic...
because of the infrastructure needed for the uploader, I�m planning to build a kind of Upload-Proxy. The Service should be like this: If you sign up on my page, you could enter your ftp-adress. If your image-uploader logs in on my page, th transfered image will be uploaded to your server and you can create new folders on your own server via the build-in dialog of the 7650.
The other possibility is to create a image-gallery on my server, with your own public and privat folders and lets say about 20mb of space.
I don�t know which version you prefer, i will realise both.
But my problem is to find the option, do you had any luck? I should documentate my work next time :-?
Wish I could help on the certificate thing, but not having a 76550 to look at / check my own hampers me a bit. Come on 7650 experts...
Hi projektil,
First of all, congrats on getting the image uploader to work on your server (I'd love to know how you done it) 😊
I think (and I only had a quick search of the phone) the option you are looking for is in Settings / Security / Certif. Management, from here you can change a level of trust assigned to certificates by selecting Options / Trust Settings / Internet (Yes / No), don't know if it works with unsigned certificates or not as I haven't had a chance to check it yet.
Hope this is what you were looking for?
Thanks,
Tsu
[quote="projektil"]Someone uploaded a picture named "ScreenShotMaloney.jpg" to my server. It seems that he/she has solved the problem with the certificated. Please contact my via mail: [email protected][/quote]
I thing it must be someone from the uk...
[quote="Tsunami_Hiroshima"]
Hi projektil,
Thanks,
Tsu[/quote]
Hi projektil,
It was me that uploaded the screenshot, had to use CSD connection as GPRS etc isn't available from my network yet.
I didn't have to do anything with certificates other than accept your one. It let me straight in, and asked if I wanted to upload to a new folder or use the existing one.
Was the image intact ? My connection was dropped during the upload?
I could see that a new image had been uploaded (even if partially), however it said that no thumbnail was available.
Will try again in a few minutes :P
[quote="Tsunami_Hiroshima"]Hi projektil,
Will try again in a few minutes :P[/quote]
Cool image, Tsunami_Hiroshima 😃
The first image was corrupt, i tried to reconstruct it from the raw-data, but i had no luck... could you be so kind to mail the first image to me so that i can find out why the upload did suceeded?
What configuration did you change in the handset? anything in the certificate-management?
Geat, the first guy upload an image to the server http://www.prinzip.com/nokia 😃
I�m currently working on the registration process and i will set up a page with the future plans for the image uploader.
This time i have a hint if you try to upload an image via gprs: use a gprs-connection, which did not use an wap-gateway and use a internet-gprs-connection instead. just use a connection for usign the 7650 as a modem for your notebook. if you are from germany, i can post the configuration for t-mobile and vodafone if needed.
henning
I have attached the original screenshot that was corrupt, my phone sat there uploading for about five minutes before it disconnected itself (same config as I used when sending the second image).
I think the problem may have been due to me having a rubbish signal, using bog standard csd connection + larger than normal file size (70k).
The problem was more than likely at my end 😞
The problem was more than likely at my end 😞[/quote]
i thought it was my fault 😞
Could everybody who successfully uploaded pictures to my server post his gprs/csd/hscsd configuration, so that i could intergrate them in the faq?
tks, henning
Image Server Config
Image Server Name:Prinzip
Access Point In Use:T-Mobile CSD
User Name:abcd
Password:abcd
URL Address:https://www.prinzip.com
Auto Folder Naming:Off
Access Point Config
Connection Name:T-Mobile CSD
Data Bearer:GSM Data
Dial-up Number:+447953968999
User Name:user
Prompt Password:No
Password:user
Authentication:Normal
Gateway IP Address:149.254.1.10
Homepage:http://wap.t-mobile.co.uk
Data Call Type:ISDN v.110
Maximum Data Speed:9600
Connection Security:Off
Session Mode:Permanent
Image Server Config
User Name:abcd
Password:abcd
my GPRS setting, singapore STARHUB
Access Point Config
Connection Name:Gee!GPRS
Data Bearer:GPRS
Access point name : shwap
User Name:star
Prompt Password:No
Password:hub
Authentication:Secure
Gateway IP Address:10.12.1.2
Homepage:http://gee-select.starhubgee.com.sg/wap/
Impressive stuff. Let me know when you're ready for a more formal announcement on the main page. feel free to e-mail me about linking etc.
A very impressed Rafe!
great site! truly impressive stuff...
thanks for making the application available 😃
nice way to test the capabilities of the phone and the network as well...
Hi All,
For those interested you can find a PDF document on Nokia's website which documents the API for making your own image upload server.
The file is called Image_Upload_Server_API_v1_0.pdf
Regards, Serge
[quote="Serge"]Hi All,
Regards, Serge[/quote]
Please notice: This document does not describe the image-uploader actually used for the 7650 and 3650, the document describes the new protocol for future handsets
