As u all shuld know, thers a new BETA version for FExplorer, version 1.12...
i lookt at the home page www.gosymbian.com but the download link isnt there :S and is says on the page that i culd download it there, and im asking u guys if enny one culd track the apps down, culd u upload it here then? i realy wont to try it... tnx (sorry for my bad eng) :frown: :con?
FExplorer v1.12....where did it go?!?!?
Tnx alot m8s 😃 ur my hearos 😉
which version of Fe exlporer will work on 6630,whether the freeware available on this site will be suitable for 6630,Pl help
All versions of Fexplorer are Freeware
And both 1.11 and 1.12b function fine.
all versions work fine on the 6630...it's a fantastic freeware app... :icon14:
thanx dear
Jj03 wrote:all versions work fine on the 6630...it's a fantastic freeware app... :icon14:
Excellent app, one of the few that has been on every Symbian phone I've owned, from the 7650 through to the 6630. Wouldn't be without it.
there are few bugs in the 1.12b version.
-try accessing your inbox then press the left joystick button then try to access c/d/e/z drive. doesnt work. it sort of hangs there
-screenshot function doesnt work on 6630 at all.
I am using the 1.12b onmy 6630 and it works fine, including the screen shot.
p51 wrote:I am using the 1.12b onmy 6630 and it works fine, including the screen shot.
Here too
try accessing your inbox via FEXplorer v1.12b then press the left joystick button to try to access C:\ drive. doesnt work. it sort of hangs there.
bug?
i can�t change my operator logo with file explorer . with oplogo the same problem .
The bug with the inbox (and others) is fixed with the last beta -
ALWAYS download a beta version from www.gosymbian.com, you'll always get the last version !!!
Cheers,
Domi.
www.gosymbian.com
Thnx Domi 😃
one stupid question :
How to install it ? I copied the SIS file into the mmc card , but can't install it ( try to use both Manager or Application ). I'm using an original Ngage.
Thansk
Don't know if this is just me but www.gosymbian.com won't open, get a 404 instead. For over a week now...
Anyway, found version 113 through a mate on IRC, and it's ace. All working (on my 6630) with excellent results. Must have tool!
Go to the following site when you want the latest FExplorer as this is the developer's official site for the software-
