Can somebody please help me with my query?I just bought a new 6630, and I have a problem occasionaly when dialling a phone call.Is it normal that a small padlock is shown when making a phone call.And occasionally it gives me connection error and does not dial,so I usually have to restart the set.Has anyone encountered this type of problems?
Thanks,and hope that someone has the right solution 😊
Query
i am not 100% sure but i don't think you should be getting that symbol when you make a call. as far as i know that symbol is to notify you of a secure connection on wap.
Even under the reception signal I have two arrows one pointing to the left and the other to the right parallel to each other.I compared it to my friends 6600 and there is only the symbol of the reception....is it normal?
pac2 wrote:Even under the reception signal I have two arrows one pointing to the left and the other to the right parallel to each other.I compared it to my friends 6600 and there is only the symbol of the reception....is it normal?
The arrows signify that a GPRS connection is available. It's all in the manual.
