Smart Movie or Makayama Media Player?
9 replies · 15,621 views · Started 18 February 2005
Can somebody please give me an honest opinion on what is better out of the Smart Movie Player or the Makayama Mobile Media Player?
Thanks in advance.
Having tried both, I definitely think Makayama does a better job at playing back the vids. However, the PC converter could use a few more options. But yes, the Mobile Media Player is clearly the better software IMO.
Strange thing though, because SmartMovie is such a good player on both UIQ and S60. I think the folks at Lonely Cat Games need to do some serious work on the S80 version, because I cannot see any reason why it should perform so poorly on S80 compared to UIQ and S60.
But on the trial it doesn't seem that you can zoom any further on the videos and the PC converter is a bit basic. Is this the case in the full version or is this not a major problem?
I have tried with some dvd movies, Feature Film, but I can't get a correct image proportions. The high of the movie appears lower than the correct size on the 9500 screen, then the film is deformed (see attached files).
I tried with TV and Home Movie formats, but the image is very small on the 9500.
Please, do you know if this size trouble can be improved?
Attachments: Got.jpg Got2.jpg
have u tried that viking dvd player? it works like makayama mobile media player, but plays smartmovie files as well. speed mobile media player with more compatibility.
hi if you are a member of the nokia club you can get a licencecode for free for mobile media player. just mail your nokia member code and they mail you an activation code.
