my phone still not working
7 replies · 1,712 views · Started 19 February 2005
hi there had been without my phone for 7 weeks today, until some kind person charged the battery up for me, i installed the new 60d firmware but my phone freezes all the time and i cant phone out or anyone in i cant even type a phone number in, but i can send texts there is no problem with the sim, i backed up the phone on memory card, and done total reset pressed 5 ,and cleared phone but its still the same wish i never touched it from first firmware and just dies on me
help have decided to get a nokia 6680 when out never had any probs with 7650 not major this this
Reset phone by pressing 5 when switching on to clear memory first, then reflash with latest firmware version 60 again.
It maybe never updated properly the first time, this should cure all your problems.
i done that and it worked but.... everytime i switch the phone off i cant make phone calls so i have to reflash and go thru the steps everytime i want to make a call about to do it again to day 8 times in all
You can always try the 50c version, not sure if it'll stop you reinstalling an old firmware, but can't see a reason why it wouldn't work.
If your phone is really not working properly after reflashing it, I would really get in touch with sendo. Have you by any chance tried another sim in your phone to see if works.
As you might have a damaged sim even if that same sim works in another phone the sendo x might not like it. I remember reading a thread about certain sims not being compatible.
Hope you get your phone working properly again.
Hand your phone back to the retailer, get your money back,
and wait for the N6680, it's just around the corner..
reflashed the phone again but did not install the back up from memory card i just installed the programs that i had downloaded with the codes, it was the memory card backup that was doing it so all new again working fine, still gonna get nokia 6680
