Sim card contacts to phone and vice versa problems.....HELP.
7 replies · 28,659 views · Started 25 October 2002
HEY DUDEZ....im having some problems transfering my contacts stored on my sim card to my phone memory and vice versa,does anyone know how its done?..if so please let me know. :cry:
open your sim card phone book from the SIM folder then select option and mark-- all then copy all your phone book to contacts.
if u just want to select some of them just mark which one do you want and copy it
i'm bad at explaining sorry 😃
CHEERS MY FRIEND.....EASY WHEN YOU KNOW HOW,ITS A GREAT PHONEMBUT IT TAKES SOME GETTING USE TOO.. 😃
There is a different format from our phone and the SIM card memory location.
In the contact list, we can customise details and each contact may contain serveral detail whereby the SIM card only can contain one detail
[quote="Edgedale"]There is a different format from our phone and the SIM card memory location.
In the contact list, we can customise details and each contact may contain serveral detail whereby the SIM card only can contain one detail[/quote]
So that means its not possible to actually copy the contacts from phone back into the sim card?
So what if just copy the numbers back to the sim card etc? Without having anyother then the numbers.
I guess its possible right?
I've been looking for a way to do this too, I can't find anything.
You used to be able to do it with the T68i, if you had more than one number for a contact it just created another contact with the same name and a different number.
It seems you can't do this with the 7650. :cry:
If anyone knows any different can you please tell us.
go to any contacts, when u r in any number, go to options, there is copy to sim direct, that's it. Too bad we need to do it 1 by 1 for all the numbers
