hi
is there any place that i can find music videos for 7650?
thanks
hi
thanks
you're joking... right?
You can try the Oplayer or Realplayer, but you're likely to run into 3 kind of disappointments:
1) It's difficult to find any music videos made for 7650
2) The audio quality is bad. Partly because of strict bandwidth limitations, partly because of poor mic in the phone
3) It'll cost you, unless you have unlimited (fixed fee) GPRS. Music video is 3-5 minutes and depending on quality the file size may be big.
** Magic **
