Hi guys.
Yestarday I bought the 9500. Perhaps I'll have to go to replace it this morning, because the internal screen shows a 'double image' on the battery and net indicators.
Please could you confirm if there is a little shadow -double image- in your commies on the indicators and the text of the Date (March 2, 2005)??
Thank you.
Ei i have that too! but it only appears on fonts, indicators, etc... i think its normal! Some kind of a design I guess...
all the communicators that i've seen (including mine) seem to have this problem. i wonder if the 9300 has this too..
I think it's just a side-effect of the transreflective screen. I hadn't actually noticed it on mine until you pointed it out.
You could change it a million times, you'd stil get the shadow 😉
Stingray72 wrote:i wonder if the 9300 has this too..
Can't make out any shadowing on mine, but I use a custom made skin so maybe that's why...
Thank you, guys. You calm me with your answers.
I have seen also the double image on a 9300 at Service Center.
I thought that it was an exclusive problem of my device.
Best regards.
Just using the word processor and Adobe Reader, there aren't any shadows in these applications. I guess it is a "Nokia feature" then 😉
I have it but it is really unnoticable and very hard to see, thats the first time I saw that
