Edit Contacts on PC
4 replies · 4,399 views · Started 28 October 2002
Yes, you can. After that, you need to use Syncronize (Nokia PC suite) to update both PC and 7650.
Thanks for the reply, how do you edit the contacts then?
I've looked through the files and couldn't see contacts or calendar when I browsed through it all quickly.
for me, i'm sync it with microsoft outlook, from there you may do the editing and sync it with your 7650
Hi there,
Sorted it through Outlook now, thank you. Is there anyway of editting your Bookmarks?
What else can you edit?
