Hi, just found these forums 😊
Erm is there anyway I can get the original background image/wallpaper back without reseting the phone, I've spent ages setting it up and after fiddling a bit I lost the original wallpaper which I kinda liked :*(
Has anyone got it they could send me, please ?
On Orange UK btw.
Many thanks.
This isnt actually the Orange UK one! Orange has its own wallpaper! Anyone?
Install SeleQ or E-filemanager on your 7650 and open the following path:
z:\System\Data
The background image is here. On a vanilla 7650 (European handset) it will be called Euro.mbm
I'm not sure what it is called on the Orange version, scroll down until you see a file with a blue icon (on SeleQ) ending in .MBM, thats your man. Copy it to your C:\Nokia\Images folder, and set it as your background as you normaly would.
Easy!
If I am not mistaken it must have the "orange" word and an mbm file extension!
[quote="omar_g"]Install SeleQ or E-filemanager on your 7650 and open the following path:
z:\System\Data
Easy![/quote]
Ah cheers.
Where can I get SeleQ and do I need an IR/Bluetooth adapter to put it on the phone or can i send it by email and install ?
me = newb with this phone 😊
You can get SeleQ from www.ximplify.com ! You can send it with IR , BT and Email!
Thanks, just worked it out and sent by email.
Thanks all.
