Inbox and memorycard
31 replies · 25,277 views · Started 19 April 2005
I just got my 3230. I want to save the incoming sms/mms on the memorycard, but i cant find the option that lets me choose that. It was possible on my other symbian phones, but i cant see that the 3230 has this option. Can someone help, or does someone know that it doesnt work?
In the phone itself u cant save incoming sms/mms on the memory card. I have no freaking clue why. But there is a software that does it, i dont remember the name of it dough.
Ok. Thanks for the answer. I used to have 6600 and 7610 and both of them had the memorycard option. But it seems that nokia left it out this time.
Hey can you please help me with the name of the software.. cos this is a real problem for me..
dominator wrote:In the phone itself u cant save incoming sms/mms on the memory card. I have no freaking clue why. But there is a software that does it, i dont remember the name of it dough.
Hello ,the software you require is called MSVDRIVEe -i cannot remember where i got it from but it is a free download anyway ,type it in on this site and it should come up somewhere (or in google).I could barely see the name of the software through the dust on my screen -does anyone have a solution for this... 😮
Nokia 3230 related questions:
Thanks a lot for the file...
a Few more question..
1) When I transfer files using bluetooth from one phone to another, all of them are go to my inbox as a message. How can i extract the file directly and transfer it to my pc.. After all bluetooth messages cannot be transferred directly to PC
2) Can you help me with a good app for backing up messages on my PC. I would like to backup all the SMSes received on my Cell phone to my PC
3) Which is the best app which will act as a good Personal information manager(PIM) or something better than the calendar which will help me track my todos
4) How can i backup the addresses on my cellphone?
5) An app to search for files
6) How can i transfer files from the phone memory to the Memory call.. an explorer type software
Thanks a lot of the assistance.
mapturner wrote:ok ,here is the file you are after.. 😊
How can I transfer my messenges from my phone memory to the memory card after I have installed this? I cant find a way.
Cheers
Luko
I have installed the MsvDriveE but when i try to open it, it gives me "App. closed MsvServer !" error :frown:
you dont need to open it. when you recieve a message now it will automatically save on your memory card.
I have activated mscdrivee but I have some old message stored in the cell. memory... someone know where this messages are (folder)?
Thank you in advance...
ciao
MAGU
Will this work for my Nokia 3230.
Is there any installation instruction. please specify
TIA
Yes it works on a 3230, send the file to the phone via bluetooth or usb, install and run once only!!! WAIT, it takes time to complete. Now if you want your old messages put on the MMC card, use like Fexplorer or SeleQ to cut and paste the files from c:\system\mail to e:\system\mail Watch this step, dont go inside mail, you may paste the folders within each other and not overwrite the new clean setup. Once everything is copied, turn OFF your phone!!! This is very important to flush out the memory, restart and ALL your memory messages will now be on the MMC card along with any Email settings etc you have configured. Doing this also clears more space from the C drive, which helps alot.
Duke.
Hi all,
Wonder if anybody can help.
Bascially I have used the msvDrive to enable storing of sms onto the mmc card. I also followed the instructions from the previous post to move the files in c:\system\Mail to e:\system\Mail.
But still, I couldn't see my old message.
I noticed that after enabling msvDrive, there are some folders created in e:\system\Mail.
I have tried various method, like copying the whole of c:\system\mail to e:\system\Mail, overwriting everything in e:\system\Mail, still it doesn't work.
I have also tried to copy only those folders and files that are not present in e:\system\Mail, from c:\system\Mail, without much success as well.
Of course, each time I have off the phone and turn it back on to check.
Would appreciate if someone could offer a more detailed instruction on how I could move my old messages from the phone memory to the mmc storage so that after I enable msvdrive, I can still see my old messages.
Thanks !
Regards
Brian
nuggo wrote:sorry but do you save the app. to the phone or MMC, or does it not matter?
The app is residing on my phone memory.... I'm not too sure if that matters or not... would be glad if somebody can clarify it ?
mapturner wrote:Hello ,the software you require is called MSVDRIVEe -i cannot remember where i got it from but it is a free download anyway ,type it in on this site and it should come up somewhere (or in google).I could barely see the name of the software through the dust on my screen -does anyone have a solution for this... 😮
I'm a newbie today. Great site though. My problem with the dust was the reason I found this site, or should I say was linked to this site.
Any way I have solved it now, through the knowledge of this member
http://www.allaboutsymbian.com/forum//forum/thread/39910/
Hope i've done this right :icon14:
regards
gill57
OceanPower Ltd,.
Re-furbished GSM Mobile Phone
Specis : looks new, good condition , good LCD, fully tested
Net work : GSM900/1800Mhz or tri bands
OEM accessories : 1 charger + 1 battery (li-ion battery)
Language : English / Chinese / Deutsch/Arabic/Francais, etc.
Packing : in color box with English manual
Mobile phone: FOB China
Description Quotation(US$/PC) Notes
Nokia 1100 50.00
Nokia 2100 52.00
Nokia 2300 100.00
Nokia 3100 100.00
Nokia 3120 110.00
Nokia 3200 120.00
Nokia 3230 294.00
Nokia 3350 50.00
Nokia 3310 34.00
Nokia 3315 34.00
Nokia 3210 23.00
Nokia 3410 35.00
Nokia 3510 39.00
Nokia 3510i 51.00
Nokia 3530 51.00
Nokia 3610 39.00
Nokia 3650 120.00
Nokia 5110 18.00
Nokia 5210 46.00
Nokia 6210 39.00
Nokia 6230 206.00
Nokia 6260 283.00
Nokia 6310 79.00
Nokia 6310i 100.00
Nokia 6150 21.00
Nokia 6110 21.00
Nokia 6510 79.00
Nokia 6108 120.00
Nokia 6100 103.00
Nokia 6610 95.00
Nokia 6600 210.00
Nokia 6820 136.00
Nokia 7110 23.00
Nokia 7200 207.00
Nokia 7210 100.00
Nokia 7250 155.00
Nokia 7250i 165.00
Nokia 7260 194.00
Nokia 7610 281.00
Nokia 7650 103.00
Nokia 8310 65.00
Nokia 8210 45.00
Nokia 8250 50.00
Nokia 8850 59.00
Nokia 8855 64.00
Nokia 8910 190.00
Nokia 8910i 200.00
Nokia 9210 200.00
Motorola T2688 15.00
Motorola V60 39.00
Motorola V60i 44.00
Motorola V66 30.00
Motorola V50 29.00
Motorola V8088 30.00
Motorola V70 52.00
Motorola M3688 85.00
Motorola M3688+ 90.00
Motorola 2988 17.00
Motorola L2000 18.00
Motorola T191 29.00
Motorola T190 28.00
Motorola T189 25.00
Motorola C200/V100 46.00
Motorola C350 43.00
Motorola C300 40.00
Motorola C330/C333 43.00
Motorola C550 73.00
Motorola 200 54.00
Motorola T720i 51.00
Motorola T722i 52.00
Motorola E365 83.00
Motorola E360 70.00
Siemens A35 15.00
Siemens A50 25.00
Siemens A55 28.00
Siemens A60 34.00
Siemens A62 54.00
Siemens A65 54.00
Siemens A70 41.00
Siemens C25 15.00
Siemens C35 16.00
Siemens C45 23.00
Siemens C55 29.00
Siemens C60 34.00
Siemens C62 41.00
Siemens C65 72.00
Siemens CFX65 112.00
Siemens CV65 98.00
Siemens M35 18.00
Siemens ME45 26.00
Siemens M50 24.00
Siemens M55 46.00
Siemens MC60 49.00
Siemens MT50 24.00
Siemens S35 18.00
Siemens S45 25.00
Siemens S55 51.00
Siemens SL55 64.00
Siemens CR62 70.00
ERICSSON 788(GSM900) 12.00
ERICSSON T10(GSM900) 14.00
ERICSSON T18(GSM900) 14.00
ERICSSON T29 21.00
ERICSSON T28 18.00
ERICSSON T39 29.00
ERICSSON T65 28.00
ERICSSON T20 21.00
SAMSUNG A100 34.00
SAMSUNG A200 46.00
SAMSUNG A300 50.00
SAMSUNG A400 37.00
SAMSUNG A800 150.00
SAMSUNG C100 95.00
SAMSUNG D410 205.00
SAMSUNG D500 330.00
SAMSUNG E700 156.00
SAMSUNG E600 154.00
SAMSUNG E630 198.00
SAMSUNG E800 192.00
SAMSUNG N100 24.00
SAMSUNG N200 30.00
SAMSUNG N500 90.00
SAMSUNG N620 58.00
SAMSUNG R220 46.00
SAMSUNG S200 129.00
SAMSUNG S300 92.00
SAMSUNG S500 106.00
SAMSUNG P400 124.00
SAMSUNG T100 85.00
SAMSUNG T200 125.00
SAMSUNG T400 97.00
SAMSUNG T500 110.00
SAMSUNG X600 107.00
SAMSUNG V200 113.00
Sony Z5/Z18 32.00
Sony Z28 38.00
Sony Z7 60.00
SonyEricsson T68i 49.00
SonyEricsson T600 39.00
SonyEricsson T300 55.00
SonyEricsson T200 32.00
SonyEricsson T100 35.00
SonyEricsson T105 50.00
SonyEricsson T310 54.00
SonyEricsson T230 55.00
SonyEricsson T618 105.00
SonyEricsson Z200 85.00
Panasonic A500 88.00
Panasonic GD55 43.00
Panasonic G51 54.00
Panasonic G50 53.00
Panasonic GD88 112.00
Panasonic GD92 21.00
Panasonic X100 91.00
Panasonic X300 113.00
Alcatel 311 26.00
Alcatel 511 31.00
Alcatel 301 20.00
Alcatel 331 32.00
Alcatel 701 25.00
Alcatel 735 85.00
Alcatel 332 49.00
Alcatel 525 32.00
Sagem 3020 30.00
Sagem 3026 29.00
Sagem 920 16.00
Sagem 922 16.00
Quality Warranty : 3 months
Regards
Tommy
Mob: 0086-13148766646
Tel: 0086-755-25590418
Fax: 0086-755-25587648
web: www.3-c.com.cn
Email: [email][email protected][/email]
hi guys,
can you give me a walkthrough on how to save the messages to the mmc for the 3230? i couldn't do it?
i'm basically upgrading from a 6600 to a 3230, how do i transer the messages, contacts and calendar from the phone memory of the 6600 to mmc to 3230 mmc?
thanks in advance. 😊
😡 hey i was wondering if u had ne luck on how to store all your phone messages to ur MMC, and also view them? as with mine, i copied the mail from C:/ to e:/system, but i cannot view them when i goto messages.... ne ideaS?
Gizmore wrote:Hi all,
Thanks !
Regards
Brian
Hi Brian! Did you finally get a chance to solve this problem? :con? I'm experiencing exactly the same situation 😡
if u want to recover phone memory msgs after using msvdrive then first of all remove the memory card and then click on msvdrive then go to messaging. u will receive a msg 'msgs cant be stored in mmc. msgs will be stored in phone memory'. after that insert your mmc. u ll get ur msgs back but not that of mmc. i.e. u cant see msgs of both memories at one time. its up to you which memory to use.
and if msvdrive is installed in mmc memory then just remove mmc and go to msgs. same thing wil happen try it. it works..........
OK, here's how I've done it:
1. Install MsvDriveE, run it and reboot.
2. Go to C:\System\Mail and copy the whole dir to E drive, but not in SYSTEM! Make another dir.
3. Uninstall MsvDriveE and delete the file msgs.ini from C:\System\Data. :icon4: Watch out what you are deleting. Reboot again.
4. Go to the dir where you copied the C:\System\Mail first time. Copy the dir and put it on E:\System\Mail. When prompted for overwrite choose "Yes".
5. Install again MsvDriveE and run it. Reboot for the last time, and VOILA! All your messages are on the E drive.
When you'll enter inbox, you'll see that the icon is now a mem card 😉
If you had alot of messages, go to C:\System and delete the whole Mail directory. He's a memory waster:tongue: Hope that I was usefull.
lol...i'm trying this app rite now...but i m confuse! :con? :con?
yeah! 3230!😎 😎
