Weird "0" Combination on cover...
6 replies · 2,110 views · Started 20 April 2005
Ei guys did anyone of u notice that the "Zero" (0) button on the COVER side is a bit messed-up??? I mean when u press "Zero" (0) three times while writing an SMS it should be a shortcut for enter right??? But mine is a bit weird... Here is the pattern:
"space", "Zero" (0), \, u, F, 7, 0, 6, and back to "space" again... is that normal???
I get Enter here on my 9300, so it must be a firmware problem on 9500s. Which firmware version do you guys have?
I have the pattern as described above with firmware 4.44.
To Raven:
Do you mean space? What happens when you push the "0" more than one time?
There is no pattern on the 9300?
What do you mean, upponalle? 'Space' and '0' is the same button... When I press '0' (zero) three times I get 'Enter' (Space - zero - Enter) - (9300 v.4.53).
Raven wrote:What do you mean, upponalle? 'Space' and '0' is the same button... When I press '0' (zero) three times I get 'Enter' (Space - zero - Enter) - (9300 v.4.53).
But that is what I meant. In the 9500 there seems to be the above pattern. Either it is meant to be like that or it is a bug that has been fixed in the 9300. Anyway it doesn't disturb me as I always write any message with the keyboard rather than with the keypad. 😊
