Maximum size of MMC supported on NOKIA 3230
7 replies · 4,859 views · Started 05 May 2005
Can anybody tell me the max size of MMC card they have personally used with 3230 without any compatibility problems or crashes. Also if RS MMC card is compatible or you have to use DV RS MMC as stated in NOKIA manual
i accidently put such big font not intentionally & i don't know how to reduce its size.
A new problem that i m facing is that i accidently blocked my PIN2 and now its asking for PUK2 code....how do i solve the problem pls help me...?
You call your operator's customer service and ask them to give you the PUK2 code.
Hello 😊
Regular RS MMC will work - no DV required. I am using a 1-Gigabyte "NCP" in my 3230 and iot has no problems except very slow opening of Gallery (which contains 100's of pictures).
Regards....
Thanh
