Review of PowerDesk for 9500
4 replies · 23 views · Started 10 May 2005
Since I just bought a 9500, I would like to do some reviews on the new applications for the 9500.
Powerdesk is the first that comes to mind. Nice application, pretty stable, but a bit rough on the edges (font size is too big and not customizable, task switcher is not as good as AppMan's etc). Anyone already did a review on it? If not, can I?
As far as I know that hasn't been reviewed, nor is it on the review list, so it would be great if you could do it.
Have you already registered? If not I can get you a registration code.
Cheers
Rafe
Already sent my IMEI to Ewan. Thanks anyway though.
BTW would it be possible to get an email address at allaboutsymbian ([email protected])? This would help communication to the outside world when writing reviews.
Cheers, Arjen
OK, I should have said send it to Ewan anyway!
Let me know whether you want a forwarder or a mailbox (in which case specify username and password) and I'll set up an email address for you asap.
Rafe
