Can you get the picture you'e assigned for your contacts appear when you have an incoming call from them?
Contact Picture appears when they phone??
yes appear... 😊
[quote="KrazyKol"]Can you get the picture you'e assigned for your contacts appear when you have an incoming call from them?[/quote]
Yeah, they work for me. 😉
Works for me too! 😃
😞 Me doing something wrong then.
How have you got this to work on your phones?
Edit the contact you want the picture for then go to Options>Add thumbnail, choose the picture from Images then click OK.
There you go mate, simple!
[quote="KrazyKol"]😞 Me doing something wrong then.
How have you got this to work on your phones?[/quote]
Well, go to the contact which you want the picture attached. Then at the contact -> options -> edit. When you are there, press Options -> Add thumbnail.
That will do. 😊
Sorry i2umi.
😮ops: Didn't mean to post the same thing as you at the same time!
[quote="jimbo.mars"]Sorry i2umi.
😮ops: Didn't mean to post the same thing as you at the same time![/quote]
Its okay. 😉
works fine for me! just add a thumbnail to the contact, person calls you, bang there on the screen!
Gothca, I have added pics by selecting the contact, then pressing right on the joystick and adding a pic there.
Thanks guys. 😊
[quote="KrazyKol"]Gothca, I have added pics by selecting the contact, then pressing right on the joystick and adding a pic there.
Thanks guys. 😊[/quote]
There you go! 😉
and also, just in case you didnt know, once u added the thumbnail to the contact, it will be safe to delete the picture in your images folder and still have the thumbnail with your contact - that is if you dont want to save the picture.
Hi ppl,
The contacts appear when they call but it seems to be small. Can it fit the whole screen?
-Jay-
There is no such possibility with the software included in the phone! At this point there is no 3rd party application that does this!
[quote="MaleBuffy"]There is no such possibility with the software included in the phone! At this point there is no 3rd party application that does this![/quote]
A third party application shouldn't be impossible to write, the answering machine-people should be able to do it in a day or two 😊
No its not impossible! My point was that there is no such application that exists now!
