Hi there,
im trying to connect my 9500 wifi to my router at home which is using a 64 bit wep. My 9500 however only allows for 40, 104 and 232 bits?
Any advise?
Thx
Swen
Hi there,
Any advise?
Thx
Swen
set your 9500 on 40n bits - it works for me. i too have my modem/router on a 64 bits WEP key. cheers, dovale
swain wrote:Hi there,im trying to connect my 9500 wifi to my router at home which is using a 64 bit wep. My 9500 however only allows for 40, 104 and 232 bits?
Any advise?
Thx
Swen
Yeah,
but the 64 bit key is longer than the 40 bit one. how to key it in?
Swen
swain wrote:Yeah,but the 64 bit key is longer than the 40 bit one. how to key it in?
Swen
Just key in the 64bit key. 64bit is actually 40bit + 26 control bits (or something like that - read it somewhere but cannot find it anymore).
Arjen wrote:Just key in the 64bit key. 64bit is actually 40bit + 26 control bits (or something like that - read it somewhere but cannot find it anymore).
mmm...64-bit = 24-bit init string + 40 bit private key
page 64 of the UK manual:
"WEP keys consist of a secret key and a 24-bit initialisation vector. For example, some manufacturers refer the 104-bit key as 128-bit key (104+24). Both keys offer the same level of encryption and are therefore interoperable."
This certainly works with my router/N9500
