Which is the Voice Dial Button ?????????????????????????
4 replies · 2,470 views · Started 05 November 2002
😊 Newbie question 😊 for the Jizzo's FAQ 😊
Answer: With the phone's LCD facing you and in upright position, you should see a little red button with a smiley face on it in white on the left SIDE of the phone...
Hold this for a couple of seconds for the voice dial system to start working. Obviously you will need to add voice tags in your contacts for the right contact to work. 😊
Go ahead play on 😉
Oh I forgot. This little red button also switches to handfree mode when on a call.
And there is another little red button on the right side, which is the power button (I guess you already knew that one 😊 )...
When in standby mode (idle) if you lightly press this button you will get a menu of options like lock keypad / changing profile / switch off etc..
here is the post about setting up voice tags.
http://www.allaboutsymbian.com/phpBB2/viewtopic.php?p=23907#23907
