I would like to know if somebody has found the way to fix the problem of the speakerphone too soft.
grrr... 😞
i know the trick, of creating a voice entrance for any contact, then to steal with one that doesn't exist and once fact this, you can use it and it will be heard clear and high, but when somebody calls you, this it returns to the state soft. :evil:
but... exist other way?? :-?
Thanks...
i think this is the only solution as of right now
No no, if you call someone, it'll still be high. I tried that, do the trick then call someone, and high it is!
But then you would never benefit of the trick when someone's calling you..
hmm. can't someone fix this as a little app? Alotta apps are emerging, isn't this software fixable? (i'm sure it is)
I think you should just update your version, as i heard the new versions have the speaker phone fixed (not sure)
Yeah come on someone make a lil proggie that
searches for a non existent voice contact at the start up of the phone.
you are right, alone it works when I call to somebody, but if somebody calls me, it is not possible. : (for that reason I request to the GOD so that anybody solves this problem. : (
would it be very complicated of solving with some application?? or is thing of the operating system already and does it require of something more?
:agrue:
um...
can u tell me how did u do it??
step by step... sorry... :-?
First of all, you get your phone :P
YOu add a voice tag, then you go to the stanby screen and hold the speakerphone button, it will say: "say you voice tag " (or something) YOu say a WRONG voice tag, and then it will say, "no match found" and viola!
Now call somebody, anybody, and press the speakerphone button, talk and see the difference!
[quote="sad1k981"]um...
step by step... sorry... :-?[/quote]
if you want to make the speakers louder u need to mention a name that u haven't saved as voice tag when you are prompted to do so after pressing the voice dial button. you will know that you performed the trick when you see a promt saying "no match found". u need to have at least 1 voice tag saved for this to work.
hope this is clear and will help.
i guess this issue is solved in v3.16? Mine after upgraded to v3.16, it is now loud enough even in outdoor.
It's really obvious that its a software issue, so all the people with version 3.12 should either upgrade, or someone makes a little app that fixes this forever!
(i'm hinting that somone should make an app!)
wink ... wink!
I have version 3.16. and i have the same problem too.
ok thnks..
haven't tried it yet but i'll try it when i got home..
thanks 😃
