Hi all,
Yes, you've guessed it, I've accidentally scratched my beloved 7650's screen. 😞 Well, the casing, anyway.
I can't find a list of Nokia Service Centres in the UK anywhere. Does anyone have a suitable link, or know where is best to start?
Also: Any recommended carry cases/protectors to stop this from happening again? It just seems so exposed!
http://www.unofficial7110.co.uk/uk_ncs.htm
Dunno how up to date this is, but its the list I always use.
Have phun
Flubster
Great list!
Alas, my local one won't have any 7650 spares in for a week. Bah.
To avoid this happening again, are they any particularly good cases out there designed for the 7650?
[quote="Mewcenary"]
To avoid this happening again, are they any particularly good cases out there designed for the 7650?[/quote]
Dont know any good Nokia cases (I use a handy case from Samsonite, its very suitable for the 7650), but to avoid scratching the screen I bought some Palm screen foils from m-line (www.mline.com). I cut them so they fit the screen of the 7650, this works very well, and they are so clear that you dont even see there is something on the screen.
If your local NSC are charging you for the repair (and legally they should as cosmetic/accidental damaged isnt covered under warranty) then consider buying a 7650 dummy phone from ebay. You'll get all the other parts to the phone too incase of future accidents.
mmm. but is it possible to buy through the net pieces separated from 7650?, for example, cases, keyboards, etc...
:agrue:
Hi all,
There's a black leather case from Nokia accessories for 7650, I bought mine from Finland.
cheers,
p 😃
Unless i'm very much mistaken, this conversation is regarding the actual plastic case (The shell of the phone) not leather protective cases.
for an up to date list of Nokia Service Centres goto and login to http://www.clubnokia.com and there should be a link in there some where !
If not there are numbers provided to speak to Nokia ( Club Nokia Sorry ) and they will give you a list / Phone numbers of the nearest ones to you !
Hope this helps m8e
