I ahve an icon which appeared suddenly yesterday. I have looked through my Nokia manuak but can't find anything about this icon. It is an arrow that is staraight then in the middle starts to point up. It is where you would have your bluetooth icon etc etc
Strange Icon on my 6680 display!!!!
Sounds like the call divert icon. You chould check the call divert status in the menu see if it is active or not.
If you're on Three it will always be there
Cos three are a pretty poo network this seems to be a result of voicemail being active.
Wish they'd send me a proper voicemail icon too and not some pants text message!
Mr Brainz wrote:If you're on Three it will always be thereCos three are a pretty poo network this seems to be a result of voicemail being active.
Well I am on 3 and i haven't got voicemail on because I phoned em up and asked
nicely for em to switch it off, which they propmptly did
Jay3gsm wrote:Sounds like the call divert icon. You chould check the call divert status in the menu see if it is active or not.
I agree, I think it's the call divert symbol. You can test this by cancelling all your diverts to see if the icon is no longer shown...
it happens on my 3g 6630. i tried the shops but they also dont know
Check your log to see if you have had any missed calls. Until you acknowledge them by opening the log, the symbol remains.
Prob because they dont support CHPS
Ok, guys I cancelled all my diverts and the icon has gone
